Rename parent folder with ID3 info of songs?
My music collection now:
Artist - Album\Track# - Track.mp3
I would like to change it to:
Artist - Year - Album\Track# - Track.mp3
I have managed to do this via rename - kind of. Instead of renaming the parent folder, a new subfolder is created and files are moved into it. That works, so long as there is an easy way to then push all those new folders up a level...
Put [b]..[/b] at the start of the new name and they'll be created one level up from normal.
It works for the first track in a directory, but when it gets to the second, it gives me an error saying that the filename already exists. I guess it's trying to create the folder again?
What's the actual rename that you're doing? Post a screenshot if it's easier than typing the details.
I know what the problem is - it was trying to rename track 2 with the same exact name as track 1, because that's what I told it to do.
What do I use to call forth the original name, and plug that into the equation?
Come to think of it, doing things this way would mean I still have to manually move my cover art. Maybe I'll just go through and change the numbers by hand, it'll only take an hour...
Hi,
:question: Is it possible to actually rename a folder without creating a new folder first - moving files - deleting the old folder :question:
I'd like to add the ID3-tag info {mp3year} to the album folders of my music collection:
old:
Genre\Artist\Album)\
new
Genre\Artist\Album (Year)\
regards,
Moep
It could be done using some VBScript. Not had a chance to look at it further though...
