I have a F-key that adds the modified date to a file name
from * > to: *-{modifieddate|D#ddMMyyyy}
and
a F-key that adds modified date&time to a file name
from: * > to: *-{modifieddate|D#ddMMyyyy} {modifiedtime|T#HHmmss}
In the 1st case the modified date is added without rename preview
In the 2nd case a the rename preview is shown, although, same as the 1st, there is 'ADVANCED SHOWPREVIEW' .
Except fot the modified time I do not see any difference.
Q: is it correct that the rename preview shows up in the 2nd case?
Found it! Matter solved.
Background: I have a template around my F-keys, showing what Opus action they do, the F-keys, the Shift-F keys. One day I lost the template, so I wasn't sure anymore what F-key is doing what, so, for convenience sake, I created a toolbar dropdown button listing all these keys (and descriptions).
Hence in settings the key in question was listed twice in settings. One with and one without the ''ADVANCED SHOWPREVIEW' .
Deleted the dropdown button. Things are and work fine now.
