Rename questions regarding FROM / TO usage
Hi,
I have been trying to set up a simple rename operation
Rename FROM *.* TO {dlgstring}_.jpg NUMBER 001
With that I have to problems:
  1. It works on all files in a folder. I need it only to work on the selected ones. The help suggest to omit the FROM but this makes the TO parameter not working.
  2. How can I retain the original file extension?
Regards
xbprm
Use PATTERN instead of FROM if you want it to work on selected files only.
To keep the extension use a regexp:
Rename PATTERN=".*(\.[^.]+)" TO="{dlgstring}_\1" NUMBER="001" REGEXP
Thanks leo.
