Rename window drop-downs are blank
the combo-box drop downs in the advanced rename window are show up blank on dopus v13.21 most of the time. all of them in the window are affected, Mode:, Capitalization:, etc
if i escape out of the window and hotkey back into it will come back after 3 or 4 tries
my hotkey is Ctrl + F2 with this in it..
@disablenosel
@if:$glob:dopus_Rename_Simple
Rename SIMPLE
@if:else
Rename ADVANCED
@nodeselect
i use the rename window just about daily and haven't had this happen before. can anyone else reproduce this?
Does it happen with the default theme / colors?
hmm, I'm not sure, after a re-boot i can't repoduce this myself. but it was more common than not for a couple hours. maybe this a random bug. ill chime in again if it comes back
its started doing the empty combox drop downs tonight.
i set the dopus them to default dark, which forces a dopus restart, which whould reset the dropdowns away, thou they seem to after 15 mins or so working on this project, renaming and moving some 1200 icos via size, eg, appending_{picwith}x{picheight}.ext
addtionally, ill have search for the post again i made about year ago regarding they system folders. with my theme applied in the system $ReycleBin the sorted column is white, ignoring my dark background. when the dopus defuatl theme is set its readable.
default dark
my own dark
if i toggle darkmode, to to light, then back to dark, from the setting menu this white column corrects itself.
i my them contain a lot font changes, almost everything has been changed to monospace nerd fonts with accent Zeros o0O
here a export of if it can be of help you
xDark.zip (346.3 KB)
