Suppose I have a file named somename.jpg.png which I want to rename by selecting the somename portion and applying my choice of extension.
Rename PATTERN "(.+)\." TO "\1.png" REGEXP doesn't work because it's "greedy"
Is there a way of forcing it to match the first occurrence of a period rather than the last?
Make the capture group non-greedy with a ? or use [^.] instead of ..
Rename PATTERN "(.+?)\." TO "\1.png" REGEXP
or
Rename PATTERN "([^.]+)\." TO "\1.png" REGEXP
Thanks @lxp. I so seldom use Regex that I always battle with the finer points of syntax. I tried monkeying with ? but was putting it in the wrong place. Your second method hadn't occurred to me. Neat.
