In one of Leo's videos, embedded in one of the post on the forum, he showed a hotkey function example for moving filename segments in the Advanced Rename Dialog and in a Lister. This functionality allows you to position the cursor in the filename and use the CTRL + [ or ] hotkeys control keys to shift filename segments.
Somehow along the way I seemed to have lost these hotkeys control keys I setup, they vanished from Keys tab in the Customize panel. I would like to recreate them but after quite a bit of searching on the forum I have not been able to find Leo's post with the particular video.
Edit: The post I was looking for: Examples: Custom Rename Keys (Opus 13)
Any guidance on where to locate this information would be greatly appreciated.
Edit: hotkeys control keys
Edit2: Link added to
