When the Viewer Pane is active and I select a file and quilcky press F2 to enter renaming, it exits "renaming mode" as soon as the Viewer loads the file. It's a pdf file and I'm trying to view and rename several of them, so this funcion could be really helpful.
After the file is loaded to the Viewer, the renaming process works with no issue.
