Reset Toolbars
Is it possible to restore the standard toolbars?
I've started saving all of my changes to new custom toolbars and would like to use some of the standard ones (including their buttons) as a reference. Sadly, I've already modified them.
If you delete (or rename) the standard toolbar files from the Buttons directory then Opus will re-create them next time it starts up.
Alternatively, in Customize, you can drag the default toolbar and menus from the "Default Menus" category and drop them on a new or existing toolbar.
