I cannot find this option where the other panel reflects the adjustments I do on the source panels columns.
Is that even possible?
The closest thing, is that you can create a toolbar button or hotkey sequence that executes the command below, which will autosize all columns in a dual file display to the widest width that each column uses in either file display.
Set AUTOSIZECOLUMNS=widest
[quote="kenalcock"]The closest thing, is that you can create a toolbar button or hotkey sequence that executes the command below, which will autosize all columns in a dual file display to the widest width that each column uses in either file display.
Well, at least they change on both panels....thx.
