In Opus 12 the new dialog box for copy/move operations is very nice but a little small in width, which is a problem when pathnames are very long. I can resize the dialog while the operation is going, but Opus does not seem to remember that new size and I would like not to have to resize every time. Is this possible? Am I missing something in preferences?
Size of the progress dialog isn't currently remembered.
I'm not against adding that, though the displayed From/To paths are truncated to keep the ends and remove the middle, and usually wide enough for normal paths.
Would it also be possible to add the ability to remember the screen location of the copy/move dialog? Every time I do a move of a file/folder that is large - or is a queue of moves, I have to drag the dialog out of the way into the bottom corner of my screen, so I can continue working in the main window of DOpus. Only a minor irritation though.
