Restore Dopus settings from hard drive backup
This question might already been asked but I could not find any relevant information.
I recently reinstalled Windows 10 and I forgot to backup Dopus settings.
However, I did make a backup of the whole C drive (OS) with DriveImage XML. Is there any way to restore my Dopus settings simply by getting the relevan files off the Hard Drive backup?
Yes, you can copy them over if you still have the old C drive.
See How to backup or locate your Opus configuration (Simple), under Locating the config files by hand.
Thanks.
That did the trick!
