I test it with pictures an it works good. With a double click the new picture will be open in the same viewer.
But with other files (doc,pdf, ..) the linked program is started (ex.Adobe Reader)
I'm using two screens and i would like to reach (Opus Lister on Screen 1, Viewer on Screen 2) when i click (1x) or move cursor on a file it will be open in the viewer on screen 2.
When i use the preview pane instead the place will be to small in lister for long file names
I had now the hope that after the adaptation of the script could work. But im not good in scripting.
We don't make double-clicks on document files go to our standalone viewer by default, as people usually want that to open the files in Office or Acrobat or similar. By default, only the preview pane version of our view handles document types.
If you want double-clicks on those file types to open the standalone Opus viewer, go to Settings > File Types, find the relevant types in the list, and set their Left Double-Click event to run the Opus Show command.
