HI
after latest windows update today integration does seems to be broken: Right clicking a file in an app, eg copernic desktop search, and "open folder" does now not use Opus but explorer
best Nolan
HI
best Nolan
Opening a folder from Windows Desktop, Chrome and Foobar2000 still works in all cases.
Is it only affecting Copernic, or other apps where it used to work? It's possible Copernic changed and now opens Explorer explicitly instead of using the default file manager.
i only notited it in copernic and other search apps, but DL same OPus version as installed and reinstalling seems to have fixed it for now, strange
thanks ![]()
nolan
