Hope someone can help me. I'm trying to add context menus to Directory Opus for a while now and I'm not being successful.
I've added two context menus, within the File Type menu as follows:
Open With Adobe - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat.exe" "%1"
Open With FoxIt - "C:\Program Files (X86)\Foxit Software\Foxit Phantompdf\Foxitphantompdf.Exe" "%1"
However when I right click a PDF file, these two options are no where to be found.
Is Preferences / Miscellaneous / Windows Integration / Hide Windows items on file context menus (shift overrides) turned on?
If so, do they appear OK if it is turned off?
(If they do, and you want to keep it on but show those particular items, there is a way to do it, but let's check if we're on the right track before going into that.)
Thank you very much. That was exactly the problem I had. Once I removed the check mark from "Hide Windows Items on file context menus (shift overrides)" I was able to see my context menus. And to think that I could have asked this question about 10 months ago!
