Right-click menu ignore HideBasedOnVelocityId registry entry
In explorer,the context menu will be hidden if it has HideBasedOnVelocityId=639bc8, like this:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\AllFilesystemObjects\shell\copy-path]
"Icon"="imageres.dll,-5302"
"MUIVerb1"="@shell32.dll,-30329"
@="Copy Path"
"HideBasedOnVelocityId"=dword:00639bc8
but in dopus right-click menu, this menu item will not be hidden
Where is this documented?
What is a “velocity ID”?
What do numbers like 639bc8 mean?
I don't know that, I get it from third-party website;
check this site for more info:
is it possible to use original explorer context menu in dopus?
Doesn’t explain what the values mean, or why Microsoft are hiding things via that new mechanism instead of the several others they have to hide things from menus. :frowning:
by the way , dopus also ignore "position" entry,
see :
so is it possible to use original explorer context menu in dopus?
in additionly,the items order of dopus context menu have big differences with that in explorer.exe
In beyond compare, it can popup same context menu as explorer:
Clip_2024-09-15_17-52-10
so I want to know:
if not , would your team consider to add this feature?
It's not possible, no.
I have found the official doc about position registry attribute:
would you consider to follow it in dopus context menu?
beyond compare can do that,
Why is it impossible for dopus ?
