When right clicking and choosing "create short cut" nothing happens. I have to go to File/New/Shortcut to create a shortcut. I am using 12.9. This is a problem on both my Win 7 pro and Win 10 computers.
What are you right-clicking?
I'm right clicking on a folder to create a shortcut to a URL
I'm not quite sure but it sounds like you have a URL in your clipboard and you want to paste that as a shortcut?
That's not what the "Create Shortcut" context menu does. That command creates a shortcut to the item you right-clicked on.
I seem to be mistaken. Sorry, I need to click New in the right click menu and then Create Shortcut.
If the page is already open in a web browser, you can drag the icon on the left of the address bar into a folder to create a .url shortcut to it as well.
I simply mistook the right click short cut in the folder tree with the new/shortcut in the list of files window.
I have only been using DOpus for 10 or so years. ;~)
Senior Moment.
Thank you for your help.
