Right click shortcut and menu bar button for adding Readme in a folder
Hello,
As the title says, is there a button or right click shortcut to do the following in the current folder:
  1. Create a new file named readme.txt or readme.md
  2. Open this file in notepad or notepad++
  3. add by default the current date/time and windows user name to the first line of the text file.
Thanks for your responses.
Make a DOS button:
@nodeselect
@runmode:hide
echo %date% %time% - %username% > {sourcepath}readme.txt
start {apppath|notepad++}notepad++.exe {sourcepath}readme.txt
Pardon but can you tell me how to make a DOS button. A bit of guidance would hopefully make it work.
Thanks
