It takes about 8-10 seconds for the context menu to display after I right-click on a file or folder. This does not happen every time.
I'm in the early stages of testing but so far this seems to happen only with WebDrive mapped drives. This does not happen if I untick Preferences / Miscellaneous / Windows Integration / Hide Windows items on file context menus (shift overrides); unless I hold the shift button and right-click.
Below is my DebugView log:
00000001 0.00000000 [1800] [5100] dopus: --- Shell Context Menu Start ---
00000002 0.02324730 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT ".sql\shell", TypeMask: 0x1
00000003 0.02329420 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT ".sql\shell", TypeMask: 0x4
00000004 0.02334400 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT ".sql\opus", TypeMask: 0x4
00000005 0.02341530 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "SystemFileAssociations\text\shell", TypeMask: 0x1
00000006 0.02347390 [1800] [5100] dopus: AddFiletypeItemsFromReg: "edit"
00000007 0.02353710 [1800] [5100] dopus: AddFiletypeItemsFromReg: "open"
00000008 0.02376600 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "SystemFileAssociations\text\shell", TypeMask: 0x4
00000009 0.02382290 [1800] [5100] dopus: AddFiletypeItemsFromReg: "edit"
00000010 0.02402090 [1800] [5100] dopus: AddFiletypeItemsFromReg: "open"
00000011 0.02408930 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "SystemFileAssociations\text\opus", TypeMask: 0x4
00000012 0.02422690 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "SystemFileAssociations\.sql\shell", TypeMask: 0x1
00000013 0.02427170 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "SystemFileAssociations\.sql\shell", TypeMask: 0x4
00000014 0.02428440 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "SystemFileAssociations\.sql\opus", TypeMask: 0x4
00000015 0.02435300 [1800] [5100] dopus: Open-With Menu: Building...
00000016 0.02500040 [1800] [5100] dopus: Open-With Menu: Done.
00000017 0.02501710 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "OpusUnknown\shell", TypeMask: 0x4
00000018 0.02505030 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "OpusUnknown\opus", TypeMask: 0x4
00000019 0.02521780 [1800] [5100] dopus: CLSID: {23170F69-40C1-278A-1000-000100020000} (7-Zip Shell Extension) (C:\Program Files\7-Zip\7-zip.dll)
00000020 0.03657760 [1800] [5100] dopus: CLSID: {2A118EB5-5797-4F5E-8B3D-F4ECBA3C98E4} (AccExt Class) (C:\Program Files (x86)\Common Files\Adobe\CoreSyncExtension\CoreSync_x64.dll)
00000021 0.03670600 [1800] [5100] dopus: CLSID: {57FA2D12-D22D-490A-805A-5CB48E84F12A} (CirrusShellEx) (C:\Program Files\Beyond Compare 4\BCShellEx64.dll)
00000022 0.04653800 [1800] [5100] dopus: CLSID: {B089FE88-FB52-11D3-BDF1-0050DA34150D} (ESET Security Shell) (C:\Program Files\ESET\ESET Security\shellExt.dll)
00000023 0.06807010 [1800] [5100] dopus: AHI(CLSID): Already done Open-With
00000024 0.06817460 [1800] [5100] dopus: CLSID: {A470F8CF-A1E8-4f65-8335-227475AA5C46} (Encryption Context Menu) (C:\Windows\system32\shell32.dll)
00000025 0.06831220 [1800] [5100] dopus: OpusZip Menu: Building...
00000026 0.08972780 [1800] [5100] dopus: OpusZip Menu: Done.
00000027 0.08981740 [1800] [5100] dopus: AHI(CLSID): Win7Sharing
00000028 0.08998410 [1800] [5100] dopus: CLSID: {1F748829-E43F-44BC-A653-3DD2069F6F83} (WebDriveShellExtension) (C:\Program Files\WebDriveApp\bin\WebDriveShellExtension.dll)
00000029 0.10139700 [1800] [5100] dopus: CLSID: {E61BF828-5E63-4287-BEF1-60B1A4FDE0E3} (Work Folders Context Menu Handler) (C:\Windows\System32\WorkfoldersShell.dll)
00000030 0.10163980 [1800] [5100] dopus: CLSID: {90AA3A4E-1CBA-4233-B8BB-535773D48449} (Taskband Pin) (C:\Windows\system32\shell32.dll)
00000031 0.11733650 [1800] [5100] dopus: CLSID: {a2a9545d-a0c2-42b4-9708-a0b2badd77c8} (Start Menu Pin) (C:\Windows\system32\shell32.dll)
00000032 0.12901160 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "*\shell", TypeMask: 0x4
00000033 0.12908360 [1800] [5100] dopus: AddFiletypeItemsFromReg: "Open with EditPadPro 8"
00000034 0.12931029 [1800] [5100] dopus: AddFiletypeItemsFromReg: "Open with EditPadPro 8 (Elevated)"
00000035 0.12953760 [1800] [5100] dopus: AddFiletypeItemsFromReg: "removeproperties"
00000036 0.12959260 [1800] [5100] dopus: AddFiletypeItemsFromReg: "UpdateEncryptionSettingsWork"
00000037 0.13002381 [1800] AQS: System.StorageProviderId <> network
00000038 0.13009250 [1800] AQS: *** unsupported property!
00000039 0.13016610 [1800] AQS: -----------------------------------
00000040 0.13018321 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "*\opus", TypeMask: 0x4
00000041 0.13026880 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "AllFiles\shell", TypeMask: 0x4
00000042 0.13028550 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "AllFiles\opus", TypeMask: 0x4
00000043 0.13041680 [1800] [5100] dopus: AHI(CLSID): CAP no shift
00000044 0.13046511 [1800] [5100] dopus: AHI(CLSID): Blocked
00000045 0.13052030 [1800] [5100] dopus: Send-To Menu: Building...
00000046 0.13058490 [1800] [5100] dopus: Send-To Menu: Done.
00000047 0.13068800 [1800] [5100] dopus: CLSID: {474C98EE-CF3D-41f5-80E3-4AAB0AB04301} (C:\Windows\System32\cscui.dll)
00000048 6.98132944 [1800] [5100] dopus: CLSID: {596AB062-B4D2-4215-9F74-E9109B0A8153} (Previous Versions Property Page) (C:\Windows\system32\twext.dll)
00000049 6.99662542 [1800] [5100] dopus: CLSID: {a2a9545d-a0c2-42b4-9708-a0b2badd77c8} (Start Menu Pin) (C:\Windows\system32\shell32.dll)
00000050 7.01141024 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "AllFilesystemObjects\shell", TypeMask: 0x4
00000051 7.01167297 [1800] [5100] dopus: AddFiletypeItemsFromReg: "LaunchWorkfoldersControl"
00000052 7.01188183 [1800] [5100] dopus: AddFiletypeItemsFromReg: "OfflineFilesLaunchSyncCenter"
00000053 7.01210165 [1800] [5100] dopus: AddFiletypeItemsFromReg loop for HKEY_CLASSES_ROOT "AllFilesystemObjects\opus", TypeMask: 0x4
00000054 7.01223373 [1800] [5100] dopus: AddFiletypeItemsFromReg: "drop"
00000055 7.01235342 [1800] [5100] dopus: AddFiletypeItemsFromReg: "dropshift"
00000056 7.01244402 [1800] [5100] dopus: AddFiletypeItemsFromReg: "dropctrl"
00000057 7.01254654 [1800] [5100] dopus: AddFiletypeItemsFromReg: "dropalt"
00000058 7.01258564 [1800] [5100] dopus: AddFiletypeItemsFromReg: "dblclkctrl"
00000059 7.01267195 [1800] [5100] dopus: AddFiletypeItemsFromReg: "cut"
00000060 7.01302624 [1800] [5100] dopus: AddFiletypeItemsFromReg: "copy"
00000061 7.01329613 [1800] [5100] dopus: AddFiletypeItemsFromReg: "paste"
00000062 7.01358175 [1800] [5100] dopus: AddFiletypeItemsFromReg: "copyname"
00000063 7.01388741 [1800] [5100] dopus: AddFiletypeItemsFromReg: "copypath"
00000064 7.01415682 [1800] [5100] dopus: AddFiletypeItemsFromReg: "setlabel"
00000065 7.01444340 [1800] [5100] dopus: AddFiletypeItemsFromReg: "setstatus"
00000066 7.01473379 [1800] [5100] dopus: AddFiletypeItemsFromReg: "shortcut"
00000067 7.01502419 [1800] [5100] dopus: AddFiletypeItemsFromReg: "delete"
00000068 7.01531601 [1800] [5100] dopus: AddFiletypeItemsFromReg: "rename"
00000069 7.01560783 [1800] [5100] dopus: AddFiletypeItemsFromReg: "properties"
00000070 7.01594734 [1800] [5100] dopus: --- Shell Context Menu End ---
This is what my context menu looks like when it finally opens:
It makes no difference if I disable the ESET context menu item.
There is no delay in the context menu displaying if I use Windows File Explorer and right-click on a WebDrive file or folder. Why is it happening with Dopus? What else can I try?
