- Check "Preferences / File Operations / Options / Shutdown Directory Opus when all functions finish".
- (Should that be relavant, choose "Preferences / Launching Opus / Startup / Open the Default Lister" and check the two checkboxes above it.)
- Close DOpus, so that
dopus.exe
doesn't run anymore. - Running this PowerShell line should now start
dopus.exe
, run the command, and terminate again without opening any lister (can be verified, if necessary, withClipboard SET=a
):& 'C:\Program Files\GPSoftware\Directory Opus\dopusrt.exe' /cmd Set NOOP
- Now, run it twice in quick succession:
Bug: DOpus opens a lister.& 'C:\Program Files\GPSoftware\Directory Opus\dopusrt.exe' /cmd Set NOOP; & 'C:\Program Files\GPSoftware\Directory Opus\dopusrt.exe' /cmd Set NOOP
Besides solving that bug, if "Shutdown Directory Opus when all functions finish" is checked and dopus.exe
is only started because dopusrt.exe
wants to run a command, it would be good if dopus.exe
would delay its shutdown for a second or so, so that one can directly run another dopusrt.exe
command after it in the same context (still existing non-persisted variables and such).
