I have some regular sync. tasks that require different options to be chosen in the sync panel (filters, only compare existing files etc.).
I have created saved layouts with the appropriate paths, to speed this up, but the sync. options are NOT saved and I have to manually remember to modify these with each sync. session - which is an irritant as I sometimes forget and there's 10000s of thousands of files in play, so it can mean a long running compare process and only realising after this that I forget to set the settings (again, sigh!).
Is it possible to save sync. settings at all? I see several historical requests for such, and something saying it was on the ToDo list (Possible to Save Synchronize/Find Panel Options with Lister? - #2 by Leo) - but I can't see a method for doing so?
If not possible, any idea when it might come along?
Many thanks!
