Saving JS script in a Script editor removes unicode symbols and adds NULs
I have a script with an attached dialog ==SCRIPT RESOURCES so I can edit the JS part in a text editor and the resources part in the visual Script editor/dialog editor
But then from time to time when saving Dialog editor edits I get NUL inserted right before ==SCRIPT RESOURCES, and sometimes those nulls multiply :slight_smile:
Haven't noticed any other corruption, so manually removing those nulls in the editor fixes the issue temporarily
Haven't noticed which specific edits cause this
file is utf8 with bom, linefeeds as line endings (is it because of this? DOpus checks for CRs?)
Can you work out what steps are necessary to reproduce it?
I couldn't so far, I thought you might have more ideas since you know how DOpus saves those files
The only other thing I've noticed is that unless I close the dialog editor DOpus doesn't re-read resources even if I close all the tabs with dialogs opened (so if I manually edit a value in the file with all tabs closed and reopen a dialog, it has old values), so maybe it's some caching issue? Though this also doesn't introduce nulls in testing
Found the issue - various symbols like :clock1: in strings confuse Dopus, so it removes them and adds nulls, so it corrupts the main script itself (I was wondering where all my symbols have gone)
For example, this line var width_max = [sC['Max↔ 1🕐'],sC['Max↔ 2🕐']]; becomes var width_max = [sC['Max↔ 1'],sC['Max↔ 2']];
It's not about dialog editor at all (strangely enough, the symbols in XML strings survive), the main JS script save function corrupts
Thanks! Fixed in the next update.
The corruption seems gone, though the line breaks aren't preserved (lf replaced with crlf), could you please also save with the same linebreaks as the original file?
CR/LF is standard for Windows, it seems odd to want something different.
which doesn't always play nice with non-win tools, so I've set my editor to use LF even on Windows
By the way, does your xml parser support syntax-preserving mode so I could have a more readable resources view for doing some quick edits within the file without opening the dialog editor (e.g., having columns as columns, not rows, or having all height props be verticall yaligned)?
Another manifestation of (I think) this issue is that I can't export a script file with unicode symbols without corruption
So my backup.TabGroupSave🕘.opusscriptinstall in the file manager's Save As view that DOpus offers on plugin export becomes a backup.TabGroupSave�.opusscriptinstall file
That seems to be a bug in our Zip library; it's losing the second half of any Unicode surrogate pairs in the filename. WIll be fixed in the next update!
