This is a VBScript for copying the target string used in a shortcut / .link file and including any arguments to the clipboard.
This can be used either as a User Command or placed directly as a button. (I personally have it added to the context menu for .LNK files via the File Types menu.
How to add it just to .lnk file context menu:
(I have it as a User Command called "Copy_Shortcut_Target_With_Arguments" but the name doesn't matter)
The Script:
'Version: 1.0.1 - 7/1/24
Option Explicit
Dim WShell, fs, selectedItems, item, path, fExt, oSHLink, targetPath, arguments, resolvedPaths, itemIndex
Set WShell = CreateObject("WScript.Shell")
Set fs = CreateObject("Scripting.FileSystemObject")
resolvedPaths = ""
Set selectedItems = clickData.func.sourcetab.selected
If selectedItems.count = 0 Then
DOpus.Output "No files selected."
Exit Function
End If
itemIndex = 0
For Each item In selectedItems
If itemIndex > 0 Then
' Add newline character for each subsequent item added
resolvedPaths = resolvedPaths & vbCrLf
End If
path = item.realpath
fExt = fs.GetExtensionName(path)
If UCase(fExt) = "LNK" Then
Set oSHLink = WShell.CreateShortcut(path)
targetPath = oSHLink.TargetPath
arguments = oSHLink.Arguments
resolvedPaths = resolvedPaths & targetPath & " " & arguments
Else
resolvedPaths = resolvedPaths & path
End If
itemIndex = itemIndex + 1
Next
' Copy the resolved paths to the clipboard
DOpus.SetClip resolvedPaths
Set oSHLink = Nothing
Set fs = Nothing
Set WShell = Nothing
End Function
Additional Notes:
- If the script is called while a file/folder other than a shortcut is selected, it will just copy the regular path to that.
- It will work with multiple .LNK files selected - it will add each result to its own line on the clipboard.
Changes:
- 1.0.1 - Fixed it so there's not an extra newline at the end of the list on the clipboard
