Can you please either
- make the checkbox the same size as the font set for it (preferred)
- or centre it vertically with the current fontsize set for it
Checkbox layout is up to Windows.
(They’re standard checkbox controls, not our own custom controls.)
Increase system DPI, not just the dialog font in Opus, if you want everything to be larger and not just a larger font.
