Script dialog control tooltip
Cannot find any way of putting a tooltip on a script dialog control.
Please can you make this so :slight_smile:
You want to add a tooltip the the dialog itself rather than to one of its controls? Isn't that very uncommon?
To controls not dialogs, so that hovering over static text or edit or image controls will show a tool tip.
Continuing the discussion from Script dialog control tooltip:
Is there a way to add a tooltip to a script control (e.g. label)?
If not could this be included in a future release?
We'll add this in the next update.
