But is there anyone who use this script with DO13?
I use this command
HashCompare FILE SHA
Sometimes, not always, once the comparison is finished, the dialog box appears and after pressing Ok, Dopus no longer works.
No error. But it is no longer possible to use it and I have to close the application in the task manager
I've noticed now that it happens more frequently if in a dual display lister I select a file on one side and one on the other and once the comparison is finished in the dialog box I press cancel instead of ok
