option explicit
' Set Admin
' This is a script for Directory Opus.
' See http://www.gpsoft.com.au/DScripts/redirect.asp?page=scripts for development information.
' Called by Directory Opus to initialize the script
Function OnInit(initData)
initData.name = "Set Admin"
initData.desc = ""
initData.copyright = ""
initData.version = "1.0"
initData.default_enable = false
End Function
' Called when Directory Opus starts up
Function OnStartup(startupData)
Dim objCmd
Set objCmd = DOpus.NewCommand
objCmd.RunCommand("Set ADMIN=on,100")
Set objCmd = Nothing
End Function
Directory Opus Title bar does not show "administrator".
"Set ADMIN=on" will elevate a single lister window. It does not make sense to try to run that command when no listers exist.
So either you are trying to use the wrong command to do whatever you're trying to do, or you have found the right command but are trying to use it in a way which does not make sense.
We need to know what you're actually trying to do with the command to be able to help.
