Script to Clean Filenames with a set of rules
Looking for guidance:
I'm trying to create a script to clean filenames with a set of rules. I've been having ChatGPT help me with the scripting which has been usually helpful but it's stuck with this one.
Here are the rules:
I need a directory opus button that will clean the selected filenames with these rules:
Allow only these characters:
  • A-Z
  • a-z
  • 0-9
  • Spaces
Characters should be replaced as follows:
_ should be replaced with a space
“ should be removed
() should be removed
, should be replaced with a period
Any other character not listed should be replaced with a period.
It gave me this script which is not working.
@script vbscript
Option Explicit
Function OnGetNewName(ByRef getNewNameData)
    Dim strFileName, strExtension, strReplacedName, strPattern
    ' Get the original filename
    strFileName = getNewNameData.item.name_stem
    strExtension = getNewNameData.item.ext
    ' Replace characters according to the rules
    strReplacedName = Replace(strFileName, "_", " ")
    strReplacedName = Replace(strReplacedName, Chr(34), "") ' Remove quotation marks
    strReplacedName = Replace(strReplacedName, "(", "") ' Remove left parenthesis
    strReplacedName = Replace(strReplacedName, ")", "") ' Remove right parenthesis
    strReplacedName = Replace(strReplacedName, "[", "") ' Remove left bracket
    strReplacedName = Replace(strReplacedName, "]", "") ' Remove right bracket
    strReplacedName = Replace(strReplacedName, ",", ".") ' Replace commas with periods
    ' Replace all other characters not in the allowed list with a period
    strPattern = "[^A-Za-z0-9 &.-]"
    strReplacedName = ReplaceCharsWithPeriod(strReplacedName, strPattern)
    ' Combine the cleaned name with the original extension
    OnGetNewName = strReplacedName & strExtension
End Function
Function ReplaceCharsWithPeriod(str, pattern)
    Dim regex, matches, match, i
    Set regex = new RegExp
    regex.Global = True
    regex.IgnoreCase = False
    regex.Pattern = pattern
    Set matches = regex.Execute(str)
    For i = matches.Count - 1 To 0 Step -1
        Set match = matches(i)
        str = Left(str, match.FirstIndex) & "." & Mid(str, match.FirstIndex + match.Length + 1)
    Next
    ReplaceCharsWithPeriod = str
End Function
When I try to run the script from a button nothing happens. No error, nothing. I'm thinking I don't have the script setup right. Here's how the button looks. Any guidance would be most appreciated.
Thanks leo! That 3rd one was perfect.
1st one off this post of mine would also serve you well, it is not only a template for extensible renaming but handles tricky chars in downloaded files as well.
Please share your workable Script with us.
