Hi,
I'm using Directory Opus 13 Pro (licensed version) and I'm trying to create a custom script column via JScript.
The goal is to display a clickable URL in a column, based on either a CSV file or metadata such as file/folder comments. A button would then open the link from the selected file or folder.
A few days ago, my script columns were working fine. But now, even the simplest script with OnAddColumns no longer causes any column to appear in Columns > Script. I’ve tested:
- Creating the script from scratch (JS)
- Using
.ospplugin file - Copying known working examples from the forum
- Rebooting Directory Opus and Windows
Still, no script column shows up.
Even this basic example fails:
function OnInit(initData) {
initData.name = "TestCol";
initData.desc = "Test column";
function OnAddColumns(addColData) {
var col = addColData.AddColumn("TestColumn");
col.name = "Test Column";
col.label = "Test Column";
col.justify = "left";
col.type = "text";
function OnColumn(scriptColData) {
scriptColData.value = "Test OK";
The script is installed and activated, but the column never appears in the list.
Could this be a bug? Is there something that blocks OnAddColumns from running (config, cache, corrupted pref)?
Any help would be appreciated.
Thanks!
