I'm trying to display a progress window (like File Function progress window) in my button script to display progress as amount of bytes but whatever I try, no window appears
Here is a minimum example of code that I've tried (one of many unsuccessful iterations).
var DOpusFactory = DOpus.Create();
var Command = DOpusFactory.Command();
var Progress = Command.progress;
Progress.bytes = true;
Progress.Init();
Progress.Show(null, "Testing");
Progress.AddFiles(1, 32768); // test
//Progress.SetFileSize(32768); // test
for (i = 0; i < 32768; i++)
Progress.SetBytesProgress(i);
And one extra question: how to prevent auto-deselection of files after my script button operation completes? The button doesn't do anything with any selected files, so files being auto-deselected after script finishes is unrelated side-effect. I've tried the @nodeselect modifier to no avail.
