Hi there's something that is really bothering me is that when you have on in Options the "always select first item" choice, and then you have some folders formatted in a way that it uses (ordering/grouping) some custom column, DOpus first select the first item, then do the ordering/grouping thing (so if the first item selected now is at the bottom you've scrolled down), when I believe should be first ordering/grouping then select the first item. Just check it out. Thanks.
Turning on Preferences / File Displays / Options / Reset focus entry when sorting file list should stop the view from scrolling.
I'm not sure you'd want the selection to be modified as a result of an asynchronous sort completing.
Well, all I want is the same behaviour as when you just sort/group by a built-in toolbar, when you enter to a folder, selects the first item AFTER DOpus do the sorting/grouping stuff
Script columns can take a long time to populate so they are handled in a way that allows that. (Some internal columns are the same.)
