This is an example custom column to demonstrate the new custom columns feature in Opus 11.6.
Place the attached .osp file into your Script AddIns folder (/dopusdata/Script AddIns).
You will then find the "Is Modified?" column in Folder Options in the new Script category.
// The OnInit function is called by Directory Opus to initialize the script add-in
function OnInit(initData) {
// Provide basic information about the script by initializing the properties of the ScriptInitData object
initData.name = "Is Modified Column";
initData.desc = "Adds a column that indicates if a file has ever been modified.";
initData.copyright = "(c) 2014 Jonathan Potter";
// Create a new ScriptColumn object and initialize it to add the column to Opus
var cmd = initData.AddColumn();
cmd.name = "IsModified";
cmd.method = "OnIsModified";
cmd.label = "Is Modified?";
cmd.autogroup = false; // we provide our own grouping information
cmd.autorefresh = true; // auto-refresh column when file changes
cmd.justify = "center";
cmd.match.push_back("Yes"); // when searching, these are the only two options
cmd.match.push_back("No");
// Implement the IsModified column (this entry point is an OnScriptColumn event).
// The name of this function must correspond to the value specified for the method property when the column was added in OnInit
function OnIsModified(scriptColData) {
// scriptColData is a ScriptColumnData object. first check that this is the right column (it should be since we only added one)
if (scriptColData.col != "IsModified")
return;
// we don't provide a value for folders since their timestamps don't mean much
// we set the sort key to 3 so they come last (in case the user is mixing files and folders)
if (scriptColData.item.is_dir) {
scriptColData.value = "";
scriptColData.sort = 3;
// for files, are the two dates the same?
else if (new Date(scriptColData.item.create).valueOf() == new Date(scriptColData.item.modify).valueOf()) {
scriptColData.value = "No";
scriptColData.group = "Never Modified";
scriptColData.sort = 2;
// the dates are different, therefore modified
else {
scriptColData.value = "Yes";
scriptColData.group = "Modified";
scriptColData.sort = 1;
IsModifiedColumn.osp (1.04 KB)
