in a similar fashion to google
The name field in Tools > Find Files has a drop-down history.
The quick search field doesn't currently have one.
OK. Thank you
Is this being considered?
It’s in the ideas list. (The list is very long, of course!)
Thanks for the quick response. I use DO as the nexus for my paperless solution, always open right screen. Recent searches are frequent. Just so you know the use case. Thanks.
