I have a couple folders mounted via NTFS directory junctions. For example C:\Users\Me\Documents\research is actually a junction to D:\Links\research. (This was accomplished with mklink) If I do a search - something like "*.pdf" to find documents - from C:\Users\Me\Documents\research, it returns 1 PDF file, and two directories (that don't have PDF in the name or even have PDF files in them). However, if I do the search from D:\links\research, it returns everything I expect it to. This isn't a particularly big problem, merely a minor annoyance. IDK if there is anything I can change on my end to have it handle this, or if I am going to just have to deal with it. Any input is appreciated.
Do you get the same results in other search tools?
Are you using the Windows Search field at the top-right of the default toolbars, or the separate Tools -> Find Panel which uses Opus's own search functionality?
At least when it comes to the Find Panel, Opus will follow the junction as long as it is permissioned to allow its contents to be listed.
