Select-and-advance a-la Double Commander?
Hello,
In Double Commander, I can press the space bar on a selected file or folder, while the highlight moves to the next item. I can then keep pressing the space bar, selecting then multiple files at once.
Furthermore, I can even use the arrow keys to pick what file I want to add to the selection.
Here's an example:
TabTip_N2R3ipFWvs_2025-05-16_13.28
Is anything like this available in Directory Opus?
The Insert key does that by default in Opus. You can change the hotkey via Customize > Keys.
Thanks, @Leo
Good to hear there's a similar function already, although it seems it works slightly different.
When using the Insert key, Directory Opus moves to the next file, and the selection starts from there, not from the file that was initially highlighted.
Also, it is not possible to use the arrow keys, everything would be deselected at that point.
From my understanding, the only way to use the arrow keys to pick different files that are not next to each other in the list, is to hold CTRL while using the arrow keys, and then press the Space Bar.
In the example I posted above, the only keys needed are the space bar and the arrow key.
Maybe there's a way to match Double-Commander behavior?
It'll toggle the selection of the initial file, then go to the next file.
Sounds like you want to use Power Mode, not the normal Details mode.
Then you can use the arrow keys to move to the next item without changing the selection, or Insert to toggle the current item and move to the next item.
To use power mode, first turn on Preferences / File Display Modes / Power Mode / Display Power mode toolbar buttons so the options for it aren't hidden.
More options:
In Details mode:
  1. Shift drag up or down file name = select multiple contiguous file
  2. Middle click file name = select multiple noncontiguous files
  3. Ctrl+click file name = select multiple noncontiguous files
Please could you explain that to me in more detail.
  1. This is about Details mode not Power mode
  2. It is about ways to select a file with the mouse in order to take some action with it.
  3. Three ways are shown to select files in a row or intermittently.
    In a row - Shift drag up or down file name. This is a "lasso".
    Intermittently - Click the file name with the middle mouse button.
    - Ctrl+left click the file name
Thanks for the info, @jinsight
Is it possible to assign a shortcut to the middle-click function, so I can use the keyboard instead?
Yes, @lensaperture! i want to use a key (space bar) to select a file or folder and move the cursor to the next item.
