Selecting images and viewing them in the Viewer Pane?
When you select an image it displays it in the viewer pane (if on), but when you hold down the shift key and hit the down arrow key to look at the next image it doesn't display it. Is there a way to display the last selected image (not initially selected image)? I do this all the time with ACDSee and it's how I usually delete files after viewing them.
Tim
It works for me, at least in Details mode. Which mode is your lister in?
