Hi!
From here i know how to create two Location Bars: use LEFT and RIGHT arguments.
But that method won't work for Back, Forward and Up buttons. I also tried OPENINLEFT and failed too.
So how do i do that?
Hi!
For going up a level, Go UP BACK OPENINLEFT seems to work okay to me. (I suspect it only does what you want here by accident, but it does seem to.
For the Back and Forward buttons, I'm not sure if there is a better way than this kludge (which will change which side has the focus and is the source):
Set SOURCE=Left
dopusrt /cmd Go BACK
(And similar for Right, Forward, etc.)
