Separate files keep structure
I have a bunch of iPhone pictures and movies in folders named after their location. I would like to keep this structure. I want to extract the movies from the photos and keep the folder structure for both. Could someone suggest a way that Opus can help with this process? Thanks
You could do it using a Copy Filter.
Super Duper! Thanks
Switch to Flatview-Mode, select the movies, move them to a new location choosing 'Recreate Directory Structure'.
Yes... I have seen this asked in Flatview-Mode. Now I am clear on what it means. This helps also. Thanks
