Are crash dumps created matching the dates/times of the crashes?
Turning on Preferences / Folders / Folder Display / Show generic icons for: all folders may help temporarily, if you can open Preferences OK. (Try using the right-click menu from the taskbar if the lister menus aren't working.)
The crash is happening in a thread created by MSVCR90.dll, which is not part of or used by Opus. Unfortunately, the crash dumps did not reveal much more than that.
(It could also be a viewer plugin, if you have any third party ones, but none of the ones that ship with Opus use MSVCR90.dll so you can ignore viewer plugins unless you've installed some extra ones from the forum.)
As a developer, I don't believe in 'luck'. either it works or it doesn't. I'll try to find the plugin in question in about an hour. Meanwhile, please check what has changed between 10.5 and 11 because 10.5 worked like a charm on the same computer as 11 is crashing now (nothing else has changed).
Literally nothing changed between the last beta (11) and the release, except the version number.
As Leo said, it's most probably luck that you didn't see this before. The steps in the FAQ should help you pin it down. It's almost certainly a shell extension.
I use MozyHome and this has a virtual drive where you can see all the files backed up for restoring. This used to work fine, even with the beta 7 of v11. With the release version, it doesn't work.
I surely hope you get this fixed soon and don't blame my luck .
Luck can have a lot to do with it. If a shell extension has a bug where it trashes a random memory location, that could be harmless in one version where there's nothing important in that memory, and then become catastrophic if we just change the length of one string which moves code around in memory slightly and lands something in the location that is being trashed.
I'm still convinced it's a bug in DOpus. It works flawlessly and every time in beta 7 of v11 and in v10.5 and earlier.
Next to that, the lister ALWAYS crashed just after opening (while building the tree part), not randomly.
Nevertheless, if someone has the same problem with MozyHome (or other backup something), turn of the virtual drive of the tool, it could help a lot .
Bugs in the Mozy shell extension have caused problems before, FWIW, and the crash dumps shows it creating multiple threads within the host process, which isn't a good idea for shell extensions.
