Set background for current active lister
I'm trying to set the background image for the active lister temporarily.
I used to be able to achieve it with folder formats which used to have image background definitions.
The setting Set BACKGROUNDIMAGE "filedisplay:/mypictures/butterfly-tile.png" makes a permanent change.
How do I just set the background temporarily?
Add BACKGROUNDIMAGEOPTS=local to the command.
Thanks again Jon. Do you have any interviews on YouTube? I'd like to hear your story....
