Set double-click a ZIP archive file to automatically extract/unzip
Hi there,
i've set this setting in opus:
But when i click ctrl+double click on zip file it opens the zip on right side opus lister.
What am i doing wrong?
Thanks,
Manuel
The auto-extract option there is for double-clicking things like .exe files inside of archives. It doesn't do anything for double-clicks on the archives themselves (unless you have an archive inside another archive, but it wouldn't do anything very useful with those).
It's documented here: https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Prefs/Archive_Options.htm
If you want double-clicking an archive (with or without Ctrl held down) to extract the archive, that should be done via Settings > File Types, and the Events tab of the type or group you want to edit.
Editing the Archives file type group there makes the most sense, as it will cover all your archive types (not just zip).
The command to extract an archive into a sub-directory with the same name is:
Copy EXTRACT=sub HERE
Thanks Leo. Works like a charm!
Leo, can you please give me some guideance how to delete the zip after being unzipped? Thanks, Manuel
You could add the Delete command on a second line.
I tend to prefer to delete files separately in case something went wrong with the extraction (e.g. if you have so skip some of the files due to clashes and want to extract them somewhere else). Automatically deleting what might be the only copy of the data isn't always a good idea, but it's your choice.
You might like this script:
Thanks both, will try and report.
