There is something missing/wrong in the manual.
The command editor:
The manual:
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Set.htm
The command editor:
The manual:
We've corrected this for the next release.
!custom does the same as !user. The name changed a while ago and the example wasn't updated. (Old and new still work, but we'll update the example.)
!current shouldn't have been in the template. Although it technically works, it doesn't do anything useful. (It's for the Print command, so you can ask for the current format. But Set FORMAT=!current just gives you what you already have.)
