'Set SAVEFORMAT' is not saving column widths
Have a button to quickly save the folder format Set SAVEFORMAT,
most columns default to 'Auto' width and when manually adjusted and then the format saved the new column is not saved as a pixel value.
Which is expected behaviour
  • manually adjust column, click save format, done.
But this does not happen meaning the folder format dialog needs to be opened and the column width set to the new pixel value and not forgetting to click the save button.
Not sure if this is by design or just an ommision so I won't flag it as a bug.
Resizing a column in the file display won’t turn off auto-size, it just lets you temporarily adjust things. Else you’d have to turn auto-size back on every time you adjusted anything, which would be worse.
What you say makes sense, but does not cover the times when you think, 'Oh I'll save this change to the column widths' and click the Set SAVEFORMAT button made for this purpose. Only for the changes not to be saved unless the Folder Format dialog is opened, the column changed to pixel width and then the save button clicked.
Resizing the column AND wanting to save the change is different to Resizing the column temporarily.
