Just wondering about syntax or maybe it's not enabled...
What am I doing wrong here.. ?
I suspect alias' can't be used in variable declarations ?
Thanks for any pointers.
@set FFMPG = "/dopusdata/ffmpeg/bin/ffmpeg.exe"
//alias isn't being expanded
You could use a global variable but using an alias for the path would be more normal, and easier to see and edit (via Preferences).
You can run executables via aliases without having to explicitly expand them so I'm still not sure where the original issue is, but you haven't shown how you're trying to use the alias yet so maybe there's a detail I am missing.
