Hi there!
I created a button (in a menu) to set the rating for selected items. If there is an item for which the command cannot set the rating (pagefile.sys e.g), it silently skips all other selected items afterwards. So the command only works on the first part of my selection.
The command I use is something simple like this:
SetAttr META rating:2
When using the metadata panel to apply the rating, there is a requester popping up for the file that failed. After "ok"ing that, all the left items will be rated (which does not happen for SetAttr).
Thanks! o)
