Thanks. I got a little confused on the way down because the keywords differ from the properties of an item (object). I then found out that eg access is not adjustable via setattr timeshift. Is there any reason for that?
Can you set the accessed timestamp via any other methods?
Windows doesn't always maintain the "accessed" timestamp, depending on OS version / configuration and filesystem. Even when it did, they weren't very useful, since just reading the icon from something or opening the Properties dialog for it would cause it to be accessed.
