In the first search, setting items is extremely slow.
In the first search, if a long string of characters is entered using Chinese input method, when pressing enter, only the first letter will be entered into the search box. Or nothing can be inputted. In short, there will be errors.
The first time you do a search from a new version (or after changing languages), it has to build an index of all the pages. That takes a few seconds. After that it won't be done again until a new version is installed.
How about the second issues?
Does that only happen on the first search?
This situation occurs every time I open the settings dialog box and make the first input.
Thanks! I can see that being an issue. We’ll investigate.
This will be fixed in 13.3.2. Thanks for reporting it!
Thanks for your work
