Setting Tiles View
Question: Why doesn't "Tiles" appear as an option on the View menu? It only appears in the menu that shows when you right click on a pane. Small thing but it seems inconsistent.
It does on the default menus here. You're probably using your old menus rather than the new ones.
Just add the following command to your menu:
Set VIEW=Tiles
Thanks, this might explain why I have a set of toolbars with a (1) appended at the end.
