I was wondering if there is a setting or a way to disable a tab closing with a double-click. I have a condition that causes me to double click a lot, and it is bothersome to have the tab I want to work in to close. Appreciate any feedback.
Jarhead
Jarhead
Go to Settings -> Preferences -> Folder Tabs -> Options. Disable from the right "Double-click tabs to close them".
Thank you very much. I appreciate you taking the time to help me.
Jarhead
