Setting up automatic synchronization
I would like to set up an automatic timed sync for various computers to a server directory. The boss uses 3 computers, i wish to make her default directory on the server sync to the 3 computers local directories. Is there a method for this?
You could use Task Scheduler to run Opus commands via dopusrt.exe but you'd then have progress dialogs randomly appearing at those times.
If you want automated background synching, there are probably more suitable tools for doing that. e.g. RoboCopy.exe is built into Windows and can sync folders non-interactively. You could use Task Scheduler to run that as well.
I keep my computers in sync with syncthing.net.
