Is it possible to have the Share feature of Windows 10 in the right click context menu. I use it very often to share files using windows mail
Thanks
The Share menu item doesn't work outside of Explorer because it's badly designed.
Similar options sometimes exist under the Send To menu, or you might be able to make a command that sends files to Windows Mail (e.g. via the command line, if it has one).
